- May 2024 News Summary (News:5)
- RISC OS 5.30 arrives (News:12)
Choice of algorithm
Implementation
Figure 1
Figure 2
Initial problems
Figure 3
Road weighting
Implementation details
typedef struct _road_path {
  int l;
  struct _road_path *next;
  corner *c;
  struct _road_path *lnext;
} road_path;
Tweaking and improvements
Figure 4
Figure 5
